9 inch vibrations!
Old Oct 1, 2006 | 01:06 PM
spike30th's Avatar
9 inch vibrations!
Well I installed a moser 9 inch rear and a spohn driveshaft in my 97 camaro and it vibrates up around 70 mph and when I decel the whole car shakes badly. I tryed adjusting my torque arm and its set at -1.The other day I read their should only be 1/2 to 3/4 inch of travel when you disconnect the rear u-joint from the rear yoke and bottom it out into the transmission, I have about 6 inches of travel untill it bottoms out into the trans. I thought the moser 9 inch uses the stock length driveshaft. What do you guys think is this my vibration? Thats the only thing left it could be.
Old Oct 1, 2006 | 03:54 PM
jay_lt4's Avatar
Re: 9 inch vibrations!
you need a longer shaft, sounds like your trans yoke is barely in the trans, very unsafe to drive this way
my 9" used the stock length shaft but i used the large 9" yoke that is about 1.5" longer than the shorter 9" yoke, they are out there, i just picked up a spare at a swap meet last weekend
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
rvonsternberg
Sep 14, 2015 11:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
maverickmk
Sep 1, 2015 09:17 PM
