9 inch torque arm placement?
Old May 14, 2007 | 12:12 PM
starbucks's Avatar
My question is pretty simple are the provitions for the torque arm on the moser 9inch on the third member or are they on the housing. i want to by the housing and axle from moser and then later build my own third memeber but my friends seem to think the third memeber is special due to arer torque arm.
Old May 14, 2007 | 05:24 PM
There are 3 tubes welded to the housing and bolts that go through the tubes to hold the complicated torque arm support casting:
You can see two of the bolts/tubes from this rear view:
And the complete assembly from the front view:
Old May 14, 2007 | 09:25 PM
starbucks's Avatar
thank you very much!! is that a special torque arm just for 9inch or is that just a normal aftermaket one
Old May 14, 2007 | 11:23 PM
That is a standard Spohn torque arm with some extra bracing added. Its in a 3,500# 30th SS 'vert that was running mid/low 8's.
Old May 15, 2007 | 10:52 AM
starbucks's Avatar
awsome thanks alot for the help
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
realistyc
Jul 28, 2015 07:32 PM
Chevyguy358
Parts Wanted
Jul 20, 2015 07:42 PM
Noct
Jul 14, 2015 01:18 AM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
