9 inch rear end brackets??
Old Dec 20, 2004 | 05:31 PM
stockLT1's Avatar
Anyone know where to get brackets to weld onto a 9 inch ford rear end to fit under a 4th gen besides stealing them from a 7.5 GM??
There's gotta be a company somewhere that sells the brackets seperate..
Old Dec 20, 2004 | 08:22 PM
OBE1 95Z28's Avatar
Re: 9 inch rear end brackets??
Never sean anyone marketing the brackets. You could try a metal fabrication shop using the stock rear as a model. The tricky part is the torque arm mounting plate.
Old Dec 20, 2004 | 08:24 PM
OBE1 95Z28's Avatar
The other challenge is narrowing the rear to the right width and generating back caliper mounting plates.
Old Dec 21, 2004 | 10:45 AM
GREGG 97Z's Avatar
I doubt you'd find a place that sold just the brackets. Your best bet is to just pick up a broken 10 bolt off someone and cut off the brackets. You could get one for as little as $50 or so with internal damage.. Even if you did find someone selling the brackets it would cost way more than that I'm sure. As mentioned you will have to fabricate the TA mount though, which looks a bit tricky to me.
Old Dec 22, 2004 | 09:54 PM
n20ta2's Avatar
I used my stockers,cut them off with a plasma cutter.As far as the brakes are concerned use 4th gen f-body moser housing ends when you narrow it and your factory calipers will bolt right back up! I built my own torque arm bracket that worked o.k untill I started cutting minus 1.50 60fts then it bent,currie enterprises will sell you the bracket they use on their housings moser WILL not.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
FirebirdGT
Dec 13, 2014 10:25 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
