700R4 will not go into overdrive... what to look for?
Old Aug 22, 2008 | 11:29 PM
Kage87Z's Avatar
Title pretty much says it all. Ideas? What do I check? (87 Z28, BTW) Otherwise (1,2 and 3) it runs fine.
Old Aug 23, 2008 | 11:09 AM
12SCNDZ's Avatar
4th gear (O/D) is accomplished by the 4th servo applying the 2-4 band. It could be a servo issue, but I'd suspect a control problem. TV cable adjustment will affect 4th gear operation. A stuck tv valve will also cause a no 4th symptom. A stuck valve will also affect other areas, though. In a normal cruising RPM, a 700 should shift 1-2 @ 15-20 MPH...2-3 @ 35-38 MPH. Too much tv (later shifts) will cause a no 4th symptom, also.
Check this one out. Do you have kickdown? Get it up to around 50-55 MPH, and mash the gas. Does it downshift? If not, you're probably looking at the tv valve being stuck.
Is this a fresh install, or did this just occur?
Frank
CPT
Old Aug 24, 2008 | 06:15 PM
Kage87Z's Avatar
The car has been in storage for 3.5 years or so. There was a wiring fire, where the 12 volt main going to the starter arced out against the dipstick tube. But the wiring has been replaced.
Jake Bialke
Sep 24, 2015 11:31 AM
92_RS_305
Sep 8, 2015 07:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
jimmybandana
Mar 22, 2015 07:44 PM
CaRParts102
Dec 6, 2014 08:45 AM
