6L80E tranny conversion
Old Feb 17, 2006 | 03:24 AM
  #16
Honda Hunter's Avatar
Re: 6L80E tranny conversion
From what Ive seen on the other boards it wouldnt even be worth the hassle on a LTx car. If I had a LSx I would do it.
Old Feb 17, 2006 | 08:06 AM
  #17
If it is made to bolt to an LSx engine block, it won't bolt up to an LT1. That might help in the decision making department.
Old Feb 17, 2006 | 11:07 AM
  #18
FirebatLT1's Avatar
Could you explain why? An 80s 700r4 will bolt up to an Ls1... Why couldn't you take a tranny from an LSx and bolt it up to any gen i, ii smallblock.
Old Feb 17, 2006 | 08:37 PM
  #19
LT1LE's Avatar
YOU CAN PUT A GEN 1 OR 2 TRANSMISSION ON A GEN 3 OR 4 IF YOU PURCHASE A CRANKSHAFT SPACER YOU WILL NEED AN LSX FLYWHEEL AND A NON-LSX TORQUE CONVERTER
YOU CAN PUT A GEN 3 OR 4 TRANSMISSION ON A GEN 1 OR 2 IF YOU GET THE CORVETTE VERSION OF THE TRANSMISSION AS IT USE THE GEN 1 & 2 1.703" PILOT HOLE FOR THE CONVERTER. YOU WILL NEED TO GET AN LS1 F-BODY BELLHOUSING
Old Feb 17, 2006 | 08:57 PM
  #20
MyShibbyZ28's Avatar
So basically if it mates up to an LSX than you're good, but LTX needs an LSX flywheel and an LTX converter (30 spline).
That's what I've gotten out of this so far.
Old Feb 17, 2006 | 09:17 PM
  #21
LT1LE's Avatar
IF YOU HAVE AN LSX ENGINE IT WILL BOLT RIGHT UP.
IF YOU HAVE A PRE-LSX ENGINE YOU NEED A CORVETTE 6L80E TRANSMISSION,
A LSX F-BODY BELLHOUSING, A 2007 2WD TAHOE TAIL HOUSING, A PRE-LSX FLYWHEEL AND TORQUE CONVERTER.
Old Feb 17, 2006 | 09:59 PM
  #22
I was pretty sure the bolt pattern is not the same.
Old Feb 17, 2006 | 10:27 PM
  #23
LT1LE's Avatar
IT IS... ALL SBC AND BBC HAVE THE SAME BELLHOUSING BOLT PATTERN
THE LSX ENGINE IS MISSING THE TOP PASSENGER SIDE BOLT HOLE
AS IT RUN'S IN TO NUMBER 8 CYLINDER.
Old Feb 18, 2006 | 12:00 AM
  #24
GreenDemon's Avatar
Originally Posted by 96WS6TA
As a Benz tech I drive vehicles every day with a 7 speed auto and I can tell you it is quite amazing how the engine stays in the power band. Also, it is the same size as their old 5 speed auto.
Hopefully they'll increase torque capacity of the 722.9 so they can mate it to the m275 sometime in the future. Should make the "65" models even more ridiculous.
Old Feb 19, 2006 | 10:03 AM
  #25
96WS6TA's Avatar
Yea, we have been waiting for the "type 9" (seven speed auto) to be put behind a blown or turboed AMG. The 65's have so much torque (more than 700 ft/lbs) that I don't think they really need 7 gears. I would like to drive an E55 with the 7-speed however. It looks like Benz is moving away from blowers on their new generation of V-8's. It seems as though everything will be N/A except the V-12's. I think BMW has been giving Benz crap about using blowers to get high HP.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
