4L60E to T56 conversion??
Old Jan 12, 2007 | 09:47 PM
camarodude8703's Avatar
Talking 4L60E to T56 conversion??
I kinda know what i need but what is all needed to swap my 94 Z from a auto to a 6 speed conversion.. I've been thinkin about it for a while but since i just blew my second 4L60E i think that it's time.. please help!!!
Old Jan 13, 2007 | 02:29 PM
Help?
Old Jan 13, 2007 | 02:48 PM
paul463's Avatar
The simplest way is to buy a conversion. They pop up for sale frequently on this site. It should include the trans,bellhousing,clutch,pressure plate,flywheel,crossmember,pedals,hydraulics,lines ,all bolts, and a shifter. You'll also need a shift plate for the console, some wiring pigtails, and a retune on your PCM. Depending on your current rear ratio you may want to change that as well. There is at least one site on the internet that is extremely informative. Hopefully someone can chime in here with that link and anything else I may have omitted. It is a money and work commitment but it sure is fun rowing six gears in one of these!
Old Jan 14, 2007 | 03:42 AM
with the power i'm putting down it will be a ton of fun..lol.. thanks man..
Old Jan 14, 2007 | 11:02 AM
retromek's Avatar
I had the complete kit, including the trans (T-56) the directions etc. Blew a couple of those 4l60-e's and figured I'd be bucks-up to go ahead and make the swap. I even rebuilt the T-56 I had bought and put the billet shift fork and new synchro's
However....There are still issues in selecting the correct clutch plate-flywheel combo.
There is a shift kit and torque converter set-up for the 94 4l60-e that will pretty much make your blues go away. Mine's lasted for over a year and a half now and I'm still shifting hard spilling rider's coffee and burning rubber.
Price-wise $$$$ the correct rebuild on my 4L60-e was 2700.00 they swapped the trans.
The T-56 kit if your lucky will be the same price excluding the clutch-flywheel combo.
There's a rebuild with photo's for the T-56 on another forum
Good luck hope this helps
Chris
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
