4l60e shifting problems, paging tranny gurus
1994Z.I just put in a fresh 4l60e. When first taking off.The car acts like it only shifts up once (1st to drive.) I also have no overdrive. It runs about 2500-2800 rpm going 55-60. If I come to a stop then take off, it acts like its still in drive(engine a bit loaded like you tryed taking off in 3rd gear in a manual transmission equipped car). If I try manual shifting from L. It runs normal then when I go to 2 nothing happens then D it shifts up. I'm told I need to scan the computer to see what codes I have. Is it possible for the computer to be causing this? I would think manual shifting it should shift normally. Does the computer have that much control to cause a problem like this? Or does it sound like this fresh trans has some internal issues?
Re: 4l60e shifting problems, paging tranny gurus
hey, sounds like you've cut a servo ring....from what your saying no 2nd or 4th...right??Sounds like a servo problem ...pull the servo and check the sealing rings..It's on the out side of the tranny pass side big round thing...hope this helps Dave
Could be a servo problem like Dave said. It could also be a shift solenoid. Even in manual ranges, the computer still commands the solenoids. If a solenoid is bad, you'll get inaccurate shift scheduling. 3rd gear is "fail safe" in a 4L60E, which means both solenoids are off. Something as simple as a blown fuse can cause this...but...when it goes into fail safe (limp mode), you usually ONLY have 3rd gear.
Frank
CPT
Frank
CPT
thanks guys, can I pull the servo without special tools and with the trans still in the car? Also do I need to drain the fluid first? Should I go this route first? Or go get the car scanned.
When you reassemble, make sure the servo return spring is in place. This is the spring between the case and the servo. "glue" it (with vaseline) to the back of the servo for best results. The 2nd apply ring slides on the main servo with the flatter part facing the main servo assembly. You may need a new o-ring for the cap, if you had to cut your original. Make certain the metal retaining ring is fully seated in the case. If it's not, it will come out!
Frank
CPT
well that sucked! I cut the hell out of my hand on the cat heat shield. Anyhow I pulled the ring and cover. A smaller hockey puck piece(had back-up ring intact) - then a larger hockey puck piece(had o-ring intact) - then I couldn't get the next puck out - so I removed the ring,washer,and spring from the shaft and pushed in on it so I could get the next puck out. I assume this was the piston/servo It had a smaller and a larger back-up ring (intact) and a spring behind it. Then I put it back together. Had a helluva time getting the ring back around the cover and seated in the case. Any other suggestions?
pulled the pan to investigate. The electrical connector that hooks to a solenoid on the front drivers side(red and white wires)hidden under the trans filter, was not hooked up. Hooked it up, works great!
Magenta_Hearts
Mar 29, 2017 08:54 PM
