? for 4l60e rebuilder
Old Jun 13, 2004 | 08:24 AM
95wannabe's Avatar
I'm converting from an m6 to 4l60e, I have the new flexplate bolted in and a couple bolts snugged up on the trans. My concern is about the gap between the flexplate and the TC. It's a good 1/4" ! I've ruined front pumps on a T350 in the past because I pulled the TC out to far to get it to bolt up, but what about on a 4l60e? Does anyone know if closing that gap will pull the convertor out to far ? or is there supposed to be some type of a spacer or ring between the block and the flexplate ? I just have it bolted right up. thanks for any info!
I forgot to mention, it's in a '94Z
Old Jun 13, 2004 | 10:16 PM
Pro Built Automatics's Avatar
The clearance should be .090-.125" between the flex plate & torque converter, if more you will need to reduce it by using machined washers (3). All the washers should be identical in thickness.
Old Jun 14, 2004 | 11:13 AM
95wannabe's Avatar
Thankyou very much! I don't need anymore problems!
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Ks0209
Oct 1, 2015 07:32 AM
