4l60e Ratchet Shifter ?'s
Old Jul 24, 2006 | 03:04 PM
SevenStars's Avatar
Just to make it clear I know that you can't manually shift the 4l60e because its electronically controlled and the line pressure is to high but my question is more of a cosmetic one.
My stock shifter is broken and I got a good deal on a TCI Streetfighter shifter this weekend, TCI says it will work w/ the 4l60e but I need to know if I use this as a normal shifter and dont manually shift while driving, will my tranny be fine? The last thing I want is to have to rebuild it again. Also has anyone done this before and do you have pics?
-Stephen
Old Jul 25, 2006 | 08:55 PM
SevenStars's Avatar
Re: 4l60e Ratchet Shifter ?'s
Anyone?
Old Aug 7, 2006 | 01:40 PM
redneck01's Avatar
they are only manual shifters if you have a manual valvebody....4l60s dont have manual/reverse valve bodies, etc. the only difference is you might have to pull a lever or something to drop down into low gear...nothing big though.
Old Aug 7, 2006 | 01:52 PM
gd1996ss's Avatar
If adjusted properly, will work like the stock one, put it in drive and go! I'm not sure if they are 1-2 then 3rd and od or what, but if not most aftermarket shifters can be adjusted to there is 4 gears you could manualy shift into.
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
CARiD
Sep 7, 2015 08:21 AM
