4L60E interchange
Old Aug 25, 2006 | 02:12 PM
RE AND CHERYL's Avatar
4L60E interchange
My wifes 96 vert has a near expired tranny. I was going to rebuild it this winter but it dosn't look like it's gonna make it that long. I found a line on a cheap 4L60E from a 93 C1500 P/U. Is it the same??? I know the Z28 used a 700R4 in 93. Will this tranny work in a 96 Z28? Will the P/U tourque converter stall higher or lower?
I just need something for a few months
Thanx
Re'
Old Aug 25, 2006 | 03:33 PM
12SCNDZ's Avatar
Re: 4L60E interchange
No...The '93 and '94 4L60E's don't use a PWM (Pulse Width Modulated) solenoid for the TCC. This means the the valvebody has an extra solenoid in '95-up models.
BTW, who are you considering to do your rebuild?
Frank
CPT
Old Aug 25, 2006 | 03:54 PM
Frank
CPT
I was actually gonna contact you about that as I only live an hour away. This car is a play toy for my wife. It's gonna stay stock axcept maybe a CAI and a cat back. It won't get beat on except for the ocasional putting a mustang back in it's place.
What would you suggest?
Old Aug 25, 2006 | 05:12 PM
12SCNDZ's Avatar
Sounds like you'll be in "Performance Rebuild" territory.
All the parts are listed here.
http://www.geocities.com/cahallperfo...?1155440875562
Thanks,
Frank
CPT
Old Aug 26, 2006 | 06:40 AM
I assume HARD PARTS are parts that are broken that you won't know about thill you tear it apart?
Hopefully I don't have any. It's working fine, it slips in 1st & 2nd when you get on it hard. Driven normally it shifts fine, just takes a bit to initially go into drive and fluid looks and smells like burnt oil.
Re'
Old Aug 26, 2006 | 07:41 AM
JakeRobb's Avatar
Super Moderator
Just to be clear, this is not correct. '93-2002 A4 F-bodies, regardless of model, used the 4L60E. As Frank said, the '93-94 cars had a slightly different setup than the '95+ cars, so you'll need one from a '95+ car.
Personally, I'd just send your current one to Frank. He has the best prices and the best reputation -- can't go wrong with that combo!
Old Aug 26, 2006 | 09:34 AM
Fierotom's Avatar
the 1993 model-year has an 4L60 and from 1994 and up a 4L60E...
....putting a mustang back in it's place
Reiner, if this happens, keep me in mind please! I want the vert ....
Old Aug 26, 2006 | 01:30 PM
Dave89IROC's Avatar
yup, 93 f-bodys used the 4L60(renamed 700r4)
94 up f-bodys used the 4L60E
but, the 4L60E was around starting in 92, so all before 95 didn't have the PWM solenoid, all 95-up did
Old Aug 26, 2006 | 02:06 PM
Loadre's Avatar
The whole PWM issue can be taken care of with a simple computer reflash.
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
