4L60E interchange
4L60E interchange
My wifes 96 vert has a near expired tranny. I was going to rebuild it this winter but it dosn't look like it's gonna make it that long. I found a line on a cheap 4L60E from a 93 C1500 P/U. Is it the same??? I know the Z28 used a 700R4 in 93. Will this tranny work in a 96 Z28? Will the P/U tourque converter stall higher or lower?
I just need something for a few months
Thanx
Re'
Thanx
Re'
Re: 4L60E interchange
No...The '93 and '94 4L60E's don't use a PWM (Pulse Width Modulated) solenoid for the TCC. This means the the valvebody has an extra solenoid in '95-up models.
BTW, who are you considering to do your rebuild?
Frank
CPT
Frank
CPT
Frank
CPT
Frank
CPT
What would you suggest?
Originally Posted by RE AND CHERYL
I was actually gonna contact you about that as I only live an hour away. This car is a play toy for my wife. It's gonna stay stock axcept maybe a CAI and a cat back. It won't get beat on except for the ocasional putting a mustang back in it's place.
All the parts are listed here.
http://www.geocities.com/cahallperfo...?1155440875562
Thanks,
Frank
CPT
I assume HARD PARTS are parts that are broken that you won't know about thill you tear it apart?
Hopefully I don't have any. It's working fine, it slips in 1st & 2nd when you get on it hard. Driven normally it shifts fine, just takes a bit to initially go into drive and fluid looks and smells like burnt oil.
Re'
Re'
Personally, I'd just send your current one to Frank. He has the best prices and the best reputation -- can't go wrong with that combo!
Originally Posted by Fierotom
the 1993 model-year has an 4L60 and from 1994 and up a 4L60E...
Reiner, if this happens, keep me in mind please! I want the vert
....94 up f-bodys used the 4L60E
but, the 4L60E was around starting in 92, so all before 95 didn't have the PWM solenoid, all 95-up did
