4L60E.....help!!
4L60E.....help!!
Trans functions normal during all upshifts, even WOT. Crisp and firm.
The problem I got is that is durning the 4-2, 3-2 downshift (kickdown) is that it seems to downshift normal but then slips for a split second and catches and then shifts normal.
Any ideas what's going on? Car had 156,000 miles, trans fluid is brownish pink and probally a solid quart or more overfull. About half an inch above the full hot line maybe more.
I half a$$ checked it when I bought it and never paid attention after that. Pretty much has had these issues since I bought it 9 months ago.
The fact that it has been driven this way for 9 months is not good, either.
Probally that way for well more than 9 months. I changed all the fluids in the car when I bought it with the exception of the trans. One of those ill get it too it tomorrow deals.
I checked it when I picked it up....it was full but could of been full cold. and the same color as it is now.
Damn. Guess ill just nurse it till I get the funds for a trans from CPT.
I have no plans to ever have this car as more than a DD. It was a northern car and salt has not been very kind to it or the previous oweners. I've spent a lot of time cleaning it up, replacing tons of crap inside and outside.
I dunno. Maybe a +1 up from the base rebuild will be fine for me. At most it will receive is full exhaust and gears. No plans to dig into motor.
? No clue Frank like I said in our emails back and forth. You made a mention it could be a 96 or 97 trans. What would cause my issues if it was that wrong year and what can I do to fix it. Also how do I check for the year of the trans while in the car?
Many less than reutable transmission shops would mismatch these units when doing swaps.
If it is the wrong year, a seperator plate and valve body swap should fix it.
Frank
CPT
