4l60e delayed shift/ PLEASE respond.
Old Nov 30, 2003 | 02:39 PM
guitardedjf's Avatar
Question 4l60e delayed shift/ PLEASE respond.
I just swapped my 93 lt1 6spd for my new 94 lt1 4l60e... the car has 68 thousand miles on it... the transmission fluid seems burnt, so i am changning the fluid and filter this week....
I just had a couple of questions since i don't know much about this transmission.
from NEUTRAL... when i shift into drive, it takes a second to shift into gear... when i shift from drive, through neutral, and to reverse, it takes a COUPLE of seconds (2-4 seconds)... i am no expert, but that doesn't seem normal... the car is very quick and i don't have any complaints about going through gears 1-4
reverse solenoid?
when i back up my driveway, if i give it a little gas, the car shakes... i was guessing that the wheels were just hopping...
does that sound normal?
what kind of fluid should i use? I want to use the best possible.
I'll probably install a trans cooler at some point but a good fluid that will reduce the friction is ok in my book.
if you would like to respond directly, elysium155@yahoo.com
Thank you very much.
-Joe
Parts Wanted
May 1, 2016 10:25 AM
blac94Z
Nov 4, 2015 01:59 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
