4l60e delayed shift/ PLEASE respond.
I just swapped my 93 lt1 6spd for my new 94 lt1 4l60e... the car has 68 thousand miles on it... the transmission fluid seems burnt, so i am changning the fluid and filter this week....
I just had a couple of questions since i don't know much about this transmission. from NEUTRAL... when i shift into drive, it takes a second to shift into gear... when i shift from drive, through neutral, and to reverse, it takes a COUPLE of seconds (2-4 seconds)... i am no expert, but that doesn't seem normal... the car is very quick and i don't have any complaints about going through gears 1-4 reverse solenoid? when i back up my driveway, if i give it a little gas, the car shakes... i was guessing that the wheels were just hopping... does that sound normal? what kind of fluid should i use? I want to use the best possible. I'll probably install a trans cooler at some point but a good fluid that will reduce the friction is ok in my book. if you would like to respond directly, elysium155@yahoo.com Thank you very much. -Joe |
