4L60E 4-SPEED trans questions
Old Dec 8, 2010 | 08:05 PM
dtcustoms's Avatar
Hey guys, I recently bought a project car, 95 pontiac formula lt1 with 38,000 miles, the was purchased as a roller, I bought the engine today, but before I buy the trans I wanted to see if only certain years fit...I know this transmission was used for many chevy vehicles and before I just buy a 4l60e trans I wanted to make sure I was buying the right one.
Old Dec 11, 2010 | 11:50 PM
GreenDemon's Avatar
Re: 4L60E 4-SPEED trans questions
4L60E's aren't all equal- the V6 versions weren't as strong, may not bolt up depending on original engine. The heavy duty truck versions might work but may have a deeper pan. Possibly different torque converter and shifting characteristics based on application. 96+ OBD2 versions may require some wiring changes.
You would be well off to get a 94-95 V8 f-body 4L60E. Shouldn't be too hard considering how many people have dumped them in favor of a T56.
Old Dec 12, 2010 | 08:51 AM
At some point (95??) they switched from switched TC lockup to pulse width modulated lockup. Your trans has to match your PCM.
Old Dec 15, 2010 | 11:43 PM
TD95Z's Avatar
Not to hijack, but I'd been meaning to ask about this. I have a spare motor and trans from my old 95 Z, both of which I plan to build to eventually replace the stock pieces in my 94 TA. How can I determine the lockup type with the trans out of the car, or can I at all? Also, if it turns out not to be directly compatible, what exactly needs to be changed internally?
Brake_L8
Jan 20, 2015 09:44 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Jan 13, 2015 09:52 PM
Jan 5, 2015 07:14 PM
Lederman1976
Nov 30, 2014 05:21 AM
