4l60 Problems
Old Nov 3, 2008 | 05:05 PM
  #16
600hplt1sm's Avatar
OK so i will unplug it tomorrow, If that does work then what do i do about the lockup.
Old Nov 3, 2008 | 10:56 PM
  #17
Performabuilt's Avatar
Supporting Vendor
One thing at a time
Old Nov 4, 2008 | 01:01 AM
  #18
600hplt1sm's Avatar
Your right. I unplug the harness and try it and then ill post tomorrow afternoon.
Old Nov 4, 2008 | 11:48 AM
  #19
600hplt1sm's Avatar
Ok. I spent 1.5 hrs trying to get the main connector unhooked. Is there another way to bypass the connector, IE a relay or something. I can get my hand on it but not enough to squeeze and pull
I know 2 of the wires go to the speed sensors but the rest of them do they go to the pcm
Old Nov 4, 2008 | 02:47 PM
  #20
Supporting Vendor
You can pull the trans fuse in the fuse box this would have the same affect
Old Nov 4, 2008 | 08:03 PM
  #21
600hplt1sm's Avatar
OK Ill try it tomorrow and post the results
Old Nov 5, 2008 | 01:56 AM
  #22
600hplt1sm's Avatar
Well check this out. When i left work last night I pulled over on a down hill section of the road & i put the car in P. I then pulled the shifter down to what would normally be D, & I started to move. I got the car up to speed and @ 40mph my rpm was 1600. So at the next stop light i started out in 2nd and shifted to 3rd. I was @ 2000 rpm @ 30mph. So i realized tha car was in OD b4. So i drove about another block and i shifted from 3rd to 4th and the car did shift to my surprise. So at the next light I put the car in low and went through all the gears and it shifted fine. I dont know what happened to make it shift into 4th but as is well for now. I will keep a close eye on the situation. I want to thank you performabuilt for all you responses. Im sure I will need something in the future for my tranny and I will give you guys my buisness first. Thanks again
Steve
Old Nov 5, 2008 | 09:08 AM
  #23
Supporting Vendor
Hey just glad you got it going maybe you had a valve sticking a little or something
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Jul 4, 2005 05:00 PM
