488 gears???
Old Jul 16, 2006 | 11:13 PM
z2894droptop's Avatar
488 gears???
What is the ups and downs on steep gears? Actually I was thinking maybe 5??. I will be running 28'' tires and a beefed up 700R4. I plan on finishing 1/4 at about 140mph.
Old Jul 17, 2006 | 12:28 AM
Daniel6718's Avatar
Re: 488 gears???
that wil definately be in everdrive...even with a 28 inch tire...go with 3.73 they are fast enough and with your trap speed youll have to pull it to 7500 8000 to cross the end of the track...with that much power id actually reccoment somehtin around a 3.55 gear and a 9inch3.73 with 28 inch tires...better get that 700 built by some1 that knows what they are doing *cough* *cough* CPT
Old Jul 17, 2006 | 06:25 AM
teke184's Avatar
Re: 488 gears???
first off you better have a better rear end than the 10 bolt. gears that big will be very weak on such a small ring.
quick calculation should have you passing 140mph at 5700 rpms or so in overdrive with the 4.88s. and with 5.14s you'll be only running 132mph or so.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
