4.56 gears.
Old Jan 24, 2007 | 12:37 AM
Silver97formula's Avatar
4.56 gears.
I have a 97 Formula (w/6 speed) with 4.11 gears and many many other mods. I'm looking to put 4.56 gears in because i have to put it in 5th gear about 100 feet before the finish and i want to finish fifth gear out at about 6000. Just wondering if anyone has a 4.56 and what gear they finish in.
I'm guessing i have about 450 HP all motor and 600 HP w/ 150 shot NOS/wet. I run 315/35/17R Drag radials and many suspension parts.
Old Jan 24, 2007 | 08:23 AM
teke184's Avatar
try punching some numbers into the gear calculator.
compare what you run now at the finish line to what you would with the bigger gears.
Old Jan 24, 2007 | 08:36 AM
mdacton's Avatar
if your going to spray it stay with the 4.10's and don't shift to 5th....your losing alot with that shift....hold it out
I have a 4.57 and go through at 7100 on a 28" mickey thompson
Old Jan 24, 2007 | 08:42 AM
JakeRobb's Avatar
Super Moderator
You'd be better off going down to 3.73s so that you don't have to shift into 5th at all. Fewer shifts is better, and you're working with more than enough power to get off the line quickly with 3.73s. Plus, 4.56s would be hell on the street.
Old Jan 24, 2007 | 11:06 AM
Bandit 1's Avatar
no fifth gear, keep 4th your last
Old Jan 24, 2007 | 01:13 PM
i had 3.73 and when i went to a 4.10 i gained about .4 in the quarter. I was hoping that 4.56 would improve my time. I only drive it to work once a week so i really don't care about gas mileage. I run an 11.80 at 116mph and thought 4.56 would drop my trap time. I have no problems off the start. I spray all the way and slip very little. My 60 foot is 1.7.
Old Jan 24, 2007 | 01:17 PM
I wish i could hold it out but i'm shifting at 6400 and i tried coasting and i run a better time shifting into 5th. with your gears what do you run the 1/4 in?
Old Jan 24, 2007 | 04:33 PM
mdacton's Avatar
i'd rather not say, I haven't got the combo right but this is no street car either
You may want to shift it a little lower and run 4th out....it took me a while when I had a 6spd. to get the right shift points....I did best with a lower shift point and your light should be on when going thru the traps...that way you should be in 4th right about 600 ft. out or so, about 3 cars from the 1/8 if I remember correctly. mostly just takes some seat time
A 4.56 is going to slow you down unless you have some more RPM to work with
Nutty's96
Dec 21, 2015 06:25 AM
4586
Sep 27, 2015 01:55 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
