4.10 just dont work .....kid need HELP!!
Old Jun 11, 2006 | 01:04 PM
  #16
User56898's Avatar
Re: 4.10 just dont work .....kid need HELP!!
anyone know how much or where to get a overdrive unit. Also, is it worth keeping the gears and change the trans or just change the gears?
Old Jun 11, 2006 | 01:17 PM
  #17
anaik's Avatar
Try here.
http://search.yahoo.com/bin/search?p=gear%20vendor
Old Jun 11, 2006 | 02:07 PM
  #18
95z28_'s Avatar
I am running 4 10 in my 95 z28 that the only way to go in my eyes!!!!!
Great for the track
Old Jun 11, 2006 | 04:31 PM
  #19
User56898's Avatar
not when your at 3000rpm doin 40
Old Jun 11, 2006 | 04:32 PM
  #20
User56898's Avatar
Originally Posted by anaik
2400 dollars!!!!
rather get a 700r4 for under 800!!!
Old Jun 12, 2006 | 05:02 PM
  #21
User56898's Avatar
wouldn't it be cheaper to do a 700r4 swap. They about the same leght so you can reuse the driveshaft, the mounts, cables, etc
Old Jun 12, 2006 | 05:48 PM
  #22
LT1Formulation's Avatar
A 700 is longer, so no, you can't re-use the driveshaft. I'd look for a 200-4R instead of a 700 anyway. Has a 2.76 first gear compared to a 3.06 and the overdrive is .67 instead of .70 so your RPM's will be lower. With that trans (200) you can most likely reuse your driveshaft.
Old Jun 14, 2006 | 02:55 PM
  #23
User56898's Avatar
which can handle more power?
Old Jun 18, 2006 | 04:06 PM
  #24
jbird's Avatar
it depends on who built them. A lot of the GN guys are running beefed up 200's. The 200's can be made really strong, and so can the 700's. It's really up to you. I'm sure a built 200 would do anything you'd ever need. How wild is this 333? More or less a stock build with a bore or what?
Old Jun 19, 2006 | 10:48 AM
  #25
User56898's Avatar
not wild. only thing stock on the motor is the heads, which are ported. Def not pushing out too much power. Soon i am gettin heads and later a blower, but by the time i get a blower this trans will be long gone.
Old Jun 20, 2006 | 01:49 PM
  #26
Jameslt1TA's Avatar
I would swap in a 4 speed auto before you get rid of your gears. My auto with 4.10s is at 3k at 75 mph so it not too bad.
camy 1993
Feb 1, 2015 07:16 PM
Noer
Parts Wanted
Jan 19, 2015 10:19 AM
cmdeshon
Dec 27, 2014 10:06 AM
slocody
Feb 10, 2003 01:04 PM
