383 flywheel???
Old Jul 16, 2004 | 05:43 PM
  #16
lillbush5555's Avatar
Did some more reasearch and found the flywheel I need. It is a McLeod Part # 460-370-2c. Summit sells them for $410.99!!!! McLeod is alot more at about $525.00!!!! Is there another company out there that make 1 a little cheaper or do I have to bit the bullet and spend $410.00?
matt
Old Jul 17, 2004 | 12:08 AM
  #17
Deadcarny's Avatar
Matt, I ran into this same problem. the 2 piece seal crank has a different bolt spacing for the flywheel than the 1 piece. You need a flywheel with the correct bolt spacing. If your rotating assy was balanced, you will need a 0 balance flywheel. I called summit and told them I had a balanced 2 piece rear main crank and an LT1 style T56 and they hooked me up with a centerforce flywheel that was like 300-something bucks.....33 pounds the thing weighs. I wish I still had the part number, dude.
Old Jul 17, 2004 | 08:25 AM
  #18
well I called summit and they offer the centerforce flywheel # 700102 for $276.95 It weights 29.9 lbs and the clutch bolt is a 5 bolt pattern measuring from bolt hole to bolt hole across the flywheel 10 inches. Will this work? If so I found a company near my house that sells it for 251.97 But I would like to order it today. PLease help me out here...It is also 153 teeth.
thanks
matt
Old Jul 17, 2004 | 10:51 AM
  #19
rskrause's Avatar
Moderator
thanks
matt
I looked at CF's catalog. The 700102 should fit. It has the external balance weight. I forgot if you said your motor is internally balanced or not. If it is not internally balanced, and is balanced against a "standard" 400 counterweight there should be no balancing issues. If it has been internally balanced, the weight will need to be removed from the flywheel, and for perfect balance they flywheel should then be checked for neutral balance.
http://www.centerforce.com/centerfor...tarq=CHEVROLET
Good luck.
Rich
Old Jul 17, 2004 | 11:07 AM
  #20
yes it is EXTERNIALY balanced so I guess I will have NO problems...Thanks alot guys!!!
Old Jul 18, 2004 | 01:19 PM
  #21
Dave88LX's Avatar
I have to ask: Why are you going through so much trouble to use that crank?!?!
Old Jul 18, 2004 | 05:54 PM
  #22
Deadcarny's Avatar
Re: 383 flywheel???
He probably ordered a stroker kit and it came with the crank, or he used a SCAT crank....
Old Jul 19, 2004 | 07:44 PM
  #23
mrz28 73/97's Avatar
Re: 383 flywheel???
Contact Centerforce they make a flywheel which has the 2 pc crank flange bolt pattern with the LT1 style face to accomodate the pull off style clutch.
PN 700107 I have one new in the box.
Old Jul 20, 2004 | 09:21 PM
  #24
Re: 383 flywheel???
Thanks for all the help guys but after looking at everything I need to make it work I cant afford it now. And he also sold the motor. But again thank you to Everyone ESP. Rich
matt
Old Jul 20, 2004 | 10:26 PM
  #25
Deadcarny's Avatar
Re: 383 flywheel???
Matt I just sold my car today. I would have sold you the motor had I known you were in the market a couple months ago! I kept the 9" though...LOL!
Old Jul 20, 2004 | 10:29 PM
  #26
Re: 383 flywheel???
Shoot I asked you when u were here...You didnt want to U wanted to sell the car as a whole. O well To late now
matt
Old Jul 20, 2004 | 10:33 PM
  #27
Deadcarny's Avatar
Re: 383 flywheel???
matt
LOL, that was in Like February.....I sold the car as a whole. I bought a stock motor and was going to sell the 383 seperate before I found out the stocker I got had some broke pistons..LOL.
Old Aug 4, 2004 | 10:19 PM
  #28
Re: 383 flywheel???
well 700102 DOESNT fir..it isnt deep enough and the clutch hits the flywheel bolts...any more ideas???
Matt
Old Aug 5, 2004 | 04:36 AM
  #29
Deadcarny's Avatar
Re: 383 flywheel???
matt, sent you a pic of mine!
Old Aug 5, 2004 | 05:45 PM
  #30
Re: 383 flywheel???
well I called centerforce today and they said I need 700173 Is that right?
Matt
