3500 stall shifts
Old Apr 13, 2010 | 01:25 PM
my left foot's Avatar
3500 stall shifts
Quick question. With hi stall around 3500 at wot shifts where does your shifts land. Stock ls1 the car will shift at 5900-6100 and fall back to 5000-5200. Does that seem right for a 3500 stall. I +- 200 rpm for the stock tack being off from the factor. Thanks
Old Apr 14, 2010 | 12:18 AM
Pro Built Automatics's Avatar
The smaller the diameter of the torque converter, higher stall, and the more horsepower/torque you have will keep the rpm's from dropping as far back as a lareger diameter, lower stall, and less horsepower/torque. Some people call this "shift extension" which is "nonsense"! Your situation sounds like the torque converter is slightly on the loose side, but if you are "happy" with it....
Old Apr 14, 2010 | 04:05 AM
rskrause's Avatar
Moderator
What would be the "exected" rpm after the shift if there were no convertor "slip"? Figure that out. If it's more than 10% the converter is definitely too loose.
Rich
detroitmuscle
Jul 31, 2015 04:21 AM
wesley81
Jul 27, 2015 11:31 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
