3200 stall
Old Jan 18, 2005 | 09:03 PM
camarolover20's Avatar
3200 stall
First will a 30 spline converter out of a 700r4 work in a 97 4L60E ?
And would 3200 stall on a daily driver say 40 to 50 miles a day be hard on the motor stock motor and rear?
Old Jan 19, 2005 | 08:35 PM
12SCNDZ's Avatar
Re: 3200 stall
A 30 spline 700 converter will physically fit in your '97, but it won't work long. GM changed the lock-up strategy in '97 for the 4L60E. Instead of off/on, it was changed to allow the converter clutch to slip some. If you watch TCC percentage in a datastream (with a scanner), you'll see TCC % going all over the place. The computer commands the amount of slippage. Because of this, they had to start using a new style lining on the converter clutch. I've seen people install an early converter in a late 60E and toast the converter on a trip around the block.
As far as 3200 stall in a daily driver? I did it for 3 years with a 3200 stall 10.5" ProTorque converter without any problems. Just make sure you've got a good additional/external cooler on it. Run it "in series"...Through the radiator first, and then through the external cooler.
Frank
CPT
Old Jan 19, 2005 | 08:45 PM
THEMADTYPH00N's Avatar
Re: 3200 stall
What about an earlier 4l60, like a 95? Will a 700 converter work in that?
Old Jan 20, 2005 | 05:09 PM
12SCNDZ's Avatar
Re: 3200 stall
Yes. '97 was the first year that they weren't interchangeable with late 700 converters (as long as the converter is 30 spline).
Frank
CPT
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
