3 channel 9"
3 channel 9"
Why won't someone make a 9" rear end with 3 channel ABS on it?
For those of us that like to road race, keep our ABS and run a high hp motor there isn't much choice other than to keep throwing gears at a 10 bolt. 12 bolts are ok I guess but I want to run a locker and so far I haven't seen one availble for for the F body 12 bolts out there, along with that I think a 9" with a lightweight housing and alum. center would be only slightly heavier than a 10 bolt.
Just a question.
Just a question.
I dont were I saw it but if you order a 4 channel set from moser you can use one of the axle relucter rings if you fab up some facy mounting bracket to use you 3 channel sensor. It will take some smarts to make it work but it can be done!
Also someone took a timing gear and had it machined for a light press fit over the tranny yoke then fabed up a bracket to the rear of the tranny and relocated the sensor there to the timing gear. I dont think the amount of teeth of the gear is as important as it is for it just to have it counting something??
DONT GET A LOCKER FOR ROAD RACING !! You kill yourself trying to exit corners. as soon as you give a little gas arround a corner it locks up and jerks the car VIOLENTLY!! I have one and drag is the only purpose for it!!
You know thats really funny because thats what I thought for a long time, but a lot of the road racers I've seen use Detriot lockers, in fact the center section that I'm looking at getting has a Detroit locker in it and its out of a TransAm car.
Randy's Ring and Pinion shows a Detroit Locker for a passenger 12 bolt. If that's what used to convert to F-body.
http://www.ring-pinion.com/products/product.asp
There is a way to put abs on a 9 inch or other aftermarket rear end. I have a huge email file someone sent me on the topic. You have to make a reluctor ring to mount on the driveshaft yoke then move your ABS sensor out of the rear and mount it over the new sensor on the DS. I hope to get the gear i ordered monday and have it machined for the driveshaft this week and then this weekend install my 8.8 if it shows up. I will get some pics and try to document if this works. I can email people the email i got from another member but it is 1500k just for fair warning.
My 3-channel ABS has been working on my 9-inch (Moser) for about 3 years now. I am the one who made a reluctor out of a timing gear and mounted it on the yoke of the driveshaft. My ABS works just like stock and has never given me any problems.
Henson071
Sep 21, 2015 04:31 PM
