3.90's for a 2 series carrier?
Old Dec 27, 2007 | 10:49 AM
95mysticta's Avatar
hey guys im just swapping my 94 formula over from a4 to m6 and i want to change out my gears from 273s to 390s or 410s dont really matter. i know there are some placed out there that make lower gears for the 2 series carriers.
can someone point in the right direction here????
thanks!
Old Dec 27, 2007 | 05:31 PM
form94's Avatar
Motive gear makes up to 3.73 that is machined thicker for 2-series carriers, and richmond has them up to 3.73 also. If you want to go 3.90/4.10 you would have to use a spacer for $50 which motive gear makes for your rear. The only other option would to buy a new carrier for the 3.23 and up gear (3 series carrier). I hope this helps and also motive gears run alot quieter than richmond which run noisey no matter how there set up
.http://www.ls1speed.com/catagory.cfm.../%20Driveshaft
Quickss96
Jan 29, 2016 05:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Catmaigne
Jul 14, 2015 05:17 PM
Dr. Weir
Aug 2, 2002 02:36 AM
CW 99 Z
Jun 23, 2002 08:30 PM
