3.90 gears now available for the Strange 12 bolt
Old Dec 1, 2003 | 02:23 PM
tbyrne's Avatar
Strange is now offering a 3.90 gear ratio for their 12 bolt rear end. They will make some noise so this isn't something that they are promoting but the ratio is available.
A little info about this rear is -
PRG210
Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Torque Line posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10
$2299.99
PRGOP8
Upgrade to US/Strange 33 spline Super strength posi-unit (w/o reluctor ring - ABS on side of pumpkin)
$145.00
PRGOP14
Upgrade to US/Strange 33 spline Super strength posi-unit (w/reluctor ring - ABS on top of pumpkin)
$145.00
PRGOP10
Upgrade to aluminum support cover
$115.00
gmbbp
Options: Purchase brake backing plates to be built into rear (1998+ cars only)
$229.99
Tom
maybe2fast
Mar 16, 2015 09:45 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
SABLT194
Aug 21, 2002 07:45 PM
T/A lt1
Aug 16, 2002 11:24 AM
SABLT194
Aug 3, 2002 09:33 AM
