3.73 A4 gas mileage
3.73 A4 gas mileage
I have the stock rear axle thinking about go with a 3.73 with my A4. What's the gas mileage like on them? Do I have to recalibrated my speedo or anything at that matter?
I went from 2.73 to 3.42 and lost about 4 MPG highway, if you have 3.23's you won't loose that much. You can compare the RPM differences using a calculator like www.f-body.org/gears/ And yes, you'll have to program the PCM for the new gear ratio to keep the speedo/odo correct.
I have them in my a4 and honestly maybe i lost 3-5 mpg but what i got in return was a smile i just cant shake off. So with just the gears i would say maybe 2-3. And you will need to recalibrate your speedo. I went from 2.73 to 3.73 with a 3000 stall
CARiD
07-07-2015 08:19 AM
Campbellb48
07-05-2015 06:31 PM
