3.73 or 4.11 for my 6 speed?
Re: 3.73 or 4.11 for my 6 speed?
what do u plan on doing with ur car, do u want a highway warrior or do u do alot of drag racing
if u do drag racing i would
1: get dynoed
2: find out where my power range is
3: buy the gears that match where my power would be
thats just somthing to look at and ive been told do do many times
if ur a higway warrior then the 4.10s 4.11s might not be what u want
3.73 may be ok ,
as for that its ur choice
1: get dynoed
3.73 may be ok ,
I had 4:10's in my stock 10-bolt. When I put in the 9 inch I went with 3:89's and have regreted it ever since. I have a set of 4:11's waiting to go in and if I didn't already have those I would go with 4:30's. I trapped over 113 with the 4:10's and still did not hit the rev limiter (6400).
Originally Posted by bubba353z
With a 26" tall tire and 3.73's, you'll be at about 1700 rpm @ 70mph. 4.10's will be about 1850 rpm. Not a whole lot of difference.
-brent
Originally Posted by CreatiVe2
i will definalty agree to the highway exhaust sound level... it happens to me.. but then again i have a Loudmouth with a borla XR-1...
I've got 4:10 gears in my car with a six speed and 25" tall 315x35 bfg's on 17" ZR1 wheels. It goes through the traps in 4th gear at 6500 RPM which is perfect for me. 11:70@122mph 1:84 60' NA
Ok, Help ME out with this one please... I have a 383 with AFR 190 heads and a t56. The short block was put together at Nu-Tek and he worked the heads pretty good and cut a cam to match, 232/240 with .576/.576 lift.I have Hooker lt's and I plan on spaying every now and then......3.73's or 4.10's ???
I am not trying to make a highway basher but dont want to run out of gear either. Thanks Eric
3.73s if u do any kind of racing on a highway, or planning on spraying.
It sucks going into 5th while racing hehe
4th is good to around 124 @ 6800 with 4.11s
4th is good to around 139 @ 6800 with 3.73s
Originally Posted by sprayedtransam
There aren't too many hills here in the TX panhandle
Im a TX panhandle boy myself, im from amarillo what about you? havent i seen your name on amarilloracers.com? IMO 4.10s or 4.11s would be more fun, you lose top end, but hey who needs to do 160mph anyway?
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
