3,000 rpm @60mph
Old Oct 26, 2007 | 02:25 PM
silverz28camaro's Avatar
3,000 rpm @60mph
well i have a 2000 auto with full bolt-ons, 3.73 12-bolt and a fuddle 2800 rpm stall and a level 2 performabuilt tranny, everything seems to work properly and the car has run 12.2 @111 but at 60 it just seems to be reved kinda high
before the stall i THINK it was around 2600 rpm at 65, will the stall do this to my rpm? anyone else have this combo? my tuner set my missfire table off and converter lockup duty cycle up and tq man. off.
during normal driving i feel the 1-2 shift 2-3 shift then i think i feel another shift but the rpms only drop 200rpm
Is this normal?
Old Oct 26, 2007 | 03:19 PM
2001NBMZ28's Avatar
Are you talking about 3rd gear? According to www.f-body.org/gears/ 2950 w/3.73 = 60. Dunno, maybe it's the tune....that calc is dead on for my car, but haven't messed with the lockup duty cycle...
Old Oct 26, 2007 | 05:17 PM
Performabuilt's Avatar
Supporting Vendor
Is this normal?
Sounds like you may either not be gettig lockup or the 3-4 shift. You need to run a scanner on it t see what its being comanded to do as a first step/ Sounds more like lockup though with the rpm differential at the various speeds 4th should make for a 30 percent drop so your rpm would be much higher I would think without the 4th shift. But since your hovering around stall speed no lockup is the most likley issue. Scan the unit and check for the actual gear shift and then for lockup enable and also codes then give me a call .
Old Oct 26, 2007 | 06:47 PM
i will scan it next, the only thing i can think it is that maybe the o-ring on the input shaft was not installed or damaged during converter installation, i was extremely careful throughout the whole install but s%#t does happen. you guys said you do install that o-ring when you ship it right? I know i didn't put it on.........i should have made sure it was on there........anyway i will get it scanned and if everything comes up as good and there are signals for lock-up and the 3-4 shift then i will take a vacation day saturday and slide the tranny back and pull the converter to see if that o-ring is there.
Old Oct 26, 2007 | 08:06 PM
Supporting Vendor
We do put the oring on however yes it can be damaged but afer or when your scanning it before you do anything call me,
570-578-5686 there are many reasons for a no lockup conditions in tuning and such we should look at before you pull the trans to look at the oring,
Thanks frank at performaBuilt
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
