2800 stall speed
Old Jan 16, 2007 | 07:10 AM
wyldcdn's Avatar
2800 stall speed
I'm looking to get the Z alittle faster this year at the track.
Last year best time in 95 degree heat, 90-95% humidity
I ran a best of 8:31 averaged a 8:45 (track is roughly 60 feet short) I was told to add a few tenths so I'll stick to the '60 foot times
60 foots are 2.00-2.05's on a nearly full tank on bald Protenza's. Tank was kept full for traction; tried it half and 1/4 alot of wheel spin and 2:20's 60' s
Last run of the year I ran nitto555r's (nearly bald) still ran 2:00's
MPH won't be acurate due to track length but speeds were anywhere between 75-79 depending on weather. Launching is at 1200-1400, anymore and I spin bad and get a nasty 2:2-2:30 60'
Cars mods are
CAI by K&N, Trick Flow Elbow black powder Coated,Mid length headers (unknown maker) aftermarket Y pipe, bolt in cat delete pipe, flowmaster 3" to flowmaster muffler. Rear axle swap to a ss rear with 3:42's. Centerline rims 245/50/16 Protenza's. 160 thermostat (reprogrammed computer; for cooling, higher shift points (shifts at 6100-6200) fans, rev limiter, and speed limiter removal). Thats all I know for know, previous owner didn't know mods, I found the original owner and informed me of the mods he could recall.
Parts I have to install this spring/winter
LT4 springs, lightweight retainers, 1.6 roller rockers, MAF granatelli, BFG drag radials (245/50/16) on five spoke firebird rims.
two pending deals, stock axle housing with moser differential, with moser axles and 3:73's and the meat of the question a possiable T/C change. Its a 2800 with lockup, (I bleive mine doesn't lock up, ift goes thru 1st-OD, then thats it, thersno more slight drop in RPMS) Is that standard? I'm waiting for more info (maker,etc etc) but its brand new from a failed project. I'm unsure about a proper stall speed. This car isn't a "D.D" but I don cruise it alot when time allows, With interstate trips from time to time. I'm not looking for the wolrd, just advice if 2800 is a decent stall speed to get me moving a little faster off the line at the strip and the street. I have a few to many friends looking to bump me off to claim they are faster..LOL ...Don't mind a lose, just not gonna make it easy for them. thanx
MAF number E.O #d-471-1 for Granatelli MAF
given to me, whats the application?
Old Jan 16, 2007 | 11:56 AM
Performabuilt's Avatar
Supporting Vendor
Personally I would go with a 2800 to 3000 9.5 inch converter with the higher stall and efficiency of the small converter added to the lower weight reciprocation's mass you should get and excellent bump up
cobrakilling101
14
Mar 17, 2015 10:42 AM
94redform
Sep 8, 2002 03:27 AM
TrouserSnake
Aug 8, 2002 06:17 PM
TrouserSnake
Aug 7, 2002 12:43 PM
TrouserSnake
Jul 30, 2002 04:00 PM
