2002 vibrating driveshaft
Old Aug 10, 2015 | 10:45 AM
ryanhilsgen's Avatar
I have a 2002 ss with 100000 miles that has a vibration mostly between 50 and 60 mph. I jacked it up and took the rear wheels and ran it in 6th gear and it shakes the whole car so I'm guessing it's the driveshaft. I also took a sharpie marker and marked it while spinning the driveshaft and it seems out of round. The the universals look original but I took the shaft out and and the t doesnt look centered. Could that be an issue? Also there's no dents in the shaft. It has me stumped.
Old Aug 10, 2015 | 11:30 AM
DelSoto's Avatar
Re: 2002 vibrating driveshaft
If the 't' or journal cross is not spaced evenly inside the yoke, could be the thrust washer is worn completely out. With 100k on the clock, I would replace anyways. While the driveshaft is out, maybe a trip to a driveline specialist in your area to check balance for extra peace of mind?
Old Aug 10, 2015 | 12:13 PM
Where is there a thrust washer?
Old Aug 10, 2015 | 01:51 PM
DelSoto's Avatar
Inside the bearing cups.
Old Aug 10, 2015 | 03:14 PM
Old Aug 12, 2015 | 10:10 PM
OK I'll just replace the crosses and if that doesn't work I'll bring it to a drive line shop. Thanks for all the help!
Old Aug 18, 2015 | 10:39 PM
TGGodfrey's Avatar
Unless you are used to replacing universal joints, take it to a driveshaft shop and have them do it and rebalence the driveshaft at the same time. Universals can be a real stubborn at times. A press makes it easier but you can still pound them out with large sockets or collets. If you have an aluminum driveshaft, you can do a fair amount of damage to the ends of the shaft if your not careful.
Driveshaft work is not expensive. Last one I had to service had to go in becuase it was out of balence and it had a dent in it causing the issue. While it was there i just had them put the joints in and the whole job was only 150.00. That was a steel driveshaft.
Old Aug 18, 2015 | 11:57 PM
The 4th Gen factory u-joints can be extremely difficult to remove, because they are locked in by injecting molten nylon into an internal groove. The nylon has to be melted out before they can be pressed out. You can hammer for hours and they won't move, until the nylon is removed.
Old Sep 21, 2015 | 04:44 PM
OK guys, I replaced the universal cross but there's no change in the vibration so I had it checked for balance and they said it's fine. Could there be something in the rear end causing the vibration?
Old Sep 21, 2015 | 07:34 PM
Does the shaft still seem "out of round"?
Henson071
Dec 30, 2015 09:55 PM
drt
Sep 27, 2015 04:39 PM
autoxr166
Sep 25, 2015 04:21 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
RallyRed701/2
Jul 20, 2015 11:18 AM
