2001 SS 6-speed 3rd & 4th grind
Old Apr 16, 2008 | 05:38 AM
billscamaro's Avatar
1st and 2nd are fine, but when i shift into third and fourth it grinds.
I havent got into fifth and sixth yet so im not sure if they do or not.
anyone have any ideas of what the problem is?
Old Apr 16, 2008 | 07:14 AM
Capn Pete's Avatar
Either:
A) a clutching issue, which is not allowing full/sufficient disengagement of the clutch to allow a smooth shift.
or
B) the synchros for 3rd & 4th are getting worn out, and not allowing smooth shifts.
First, try bleeding the clutch. It can be a bit of a pain, and there are a few different methods. Do a search for a "how-to". Also, read up a little bit on the "drill mod" .
THEN, if you still have shifting issues, it's inside the tranny. A rebuild "can" be a DIY job, or there are a couple reputable 6-speed builders around if necessary .
Old Apr 16, 2008 | 09:24 AM
Alright, thanks alot
about how much is it for a rebuild?
Old Apr 16, 2008 | 09:53 AM
Capn Pete's Avatar
Try here : SixSpeedsInc
Girrrrl
Aug 20, 2015 06:17 AM
techstar
Aug 6, 2015 11:20 AM
detroitmuscle
Jul 31, 2015 04:21 AM
ricks95TA
Jul 23, 2015 12:59 AM
ricks95TA
Jul 22, 2015 10:15 PM
