2.73's to 3.73's
Old Jan 26, 2005 | 03:44 PM
blue94z28's Avatar
2.73's to 3.73's
well im switching gears and was told i need a new carrier. I was looking online and saw the eaton posi and the slp unit. I was just wondering which one would be better. Thanks
Old Jan 26, 2005 | 05:15 PM
93LT1355's Avatar
Re: 2.73's to 3.73's
Unless there is something wrong with your current carrier, I don't see why you would have to change. They make 3.73 gears for 2 series carriers.
Old Jan 26, 2005 | 05:21 PM
AmericanMuscle33's Avatar
yep, most sites will list the gears for your 2 series carrier as "Thick"...Its to make up for the +-1/4 inch of heigth advantage the 3 series carrier has.
Old Jan 26, 2005 | 05:22 PM
Capn Pete's Avatar
You can get 3.73's to fit your 2-series carrier (that's not a problem) but if you wanted to upgrade to an Eaton posi unit, then now's the time. The Eaton uses clutch packs like the "old-school posi's" used to. Otherwise you've likely got the Auburn diff, which has "cone shaped" spider gears and springs in between to maintain force and prevent the axles from turning independent. They work good, but wear out eventually.
Old Jan 26, 2005 | 05:36 PM
blue94z28's Avatar
wow i didnt know they made them in 2 series. The websites i looked at showed only three series. I wish i would have known that before i bought them. Oh well thanks for the info though i guess i will look into the auburn posi unit too.
RUENUF
Mar 13, 2016 03:37 PM
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
