1st impressions of spec stage 4
Old Oct 4, 2004 | 10:32 PM
  #16
Bob's 01SLPSS's Avatar
Re: 1st impressions of spec stage 4
Gary,
Steve said you were having problems with your flywheel, he told me to take mine when I get it and the stock one to commercial to get it balanced before the install.
Old Oct 6, 2004 | 04:48 PM
  #17
Gary 95 Z28 M6's Avatar
yeah i definetly would. i am taking my clutch and flywheel out tomorrow i think. then i will take it to commercial. hopefully i can have it back together by next weekend.
Old Oct 9, 2004 | 07:29 PM
  #18
Just an update. I pulled my clutch back out on Thursday and inspected it. I can tell by looking at the flywheel and pressure plate that something is not right. The flywheel has hot spots on only about 1/2 of it and the other half is fine. The pressure plate is the same. Another weird thing is that the disc has a perfectly even wear pattern on one side and hardly any wear on the other side. I called Spec yesterday and he told me to email him a bunch of pictures and he will let me know what they want to do. Hopefully they will send me out everything new since obviously the flywheel or pressure plate is warped. I'm shooting for getting it back on the road by next Friday!
Old Oct 9, 2004 | 07:44 PM
  #19
Klypto's Avatar
i have specIII and billet steel flywheel, first 200 miles or so were rough, now with a few grand on it, still holds like a CHAMP, broke my axle the week after i installed it at the track on 245 nittos555r's feels stock, and hasnt slipped at all since i got it, highly recomend, unless your good bit modded, a specIII is all you need, i know someone with 450+/- hp and still hold perfect with alot of abuse...
cory
Old Oct 10, 2004 | 03:14 AM
  #20
viper03af's Avatar
well i have the stage 5 for my 3.8 and the first 250 were hell beacuse of the damn iron plate squeaking (but i like a clutch that has no play i hate feathering it, i burn so many clutches up lol i can't burn this one i hope......
www.turbov6camaro.com/video.html look at the dyno vid thats my clutch seaking it so freaking loud lol
only does it now going in revers lol
Old Oct 23, 2004 | 02:50 PM
  #21
well i figured id give an update to my problem. i ended up taking the clutch and flywheel out and sending it to spec. they said they found the flywheel was out of balance so they resurfaced it and rebalanced it. they also said they found the pressure plate was out a little so they replaced it along with the disc. well i put everything back together today hoping that it would be fine. WRONG!!!! it still has the same vibration although it is a little better than before. what im going to do now is take it all back apart again and put my old flywheel on with the new stage 4 disc and pressure plate, and check it and go from there. this is really pissing me off!!!!!!
Old Oct 28, 2004 | 07:43 PM
  #22
well i finally determined the cause today. i took everything back apart and put the stock flywheel in with the new spec clutch. started it up, NO VIBRATION at all. so the cause is the f*ckin flywheel that was already rebalanced once. im taking the old flywheel and new one to an engine shop to see if they can match the balance of the new with the old. if they can't i think im going to send everything back to spec and get my money back.
Old Oct 30, 2004 | 08:59 PM
  #23
95CamaroZ-28's Avatar
Have you been sending your old flywheel to Spec to have them balance the new one accordingly?
Old Oct 31, 2004 | 08:31 AM
  #24
yes i already sent it back once.
Old Oct 31, 2004 | 01:26 PM
  #25
That's no good. Having a flywheel incorrectly balanced can make life hard on bearings.
Old Nov 1, 2004 | 03:11 PM
  #26
CoUnTryMuZiCZ28's Avatar
Originally Posted by Gary 95 Z28 M6
If I were you I would get the stage 4. Mine is great except for one problem. I finally got the 500 break in miles on it a couple weeks ago and I got on it for the first time and as soon as the rpms got above 3500 the car started vibrating pretty bad. I have the billet steel flywheel too. I suspect either the flywheel or pressure plate is out of balance. I'm taking the car apart on wed. and then take everything to commercial engine to have them check the balance on it. After that I'm calling Spec again. Its a bunch of bull sh*t that I wasn't planning on dealing with. Oh well, thats what happens with aftermarket stuff.
Since you bought a new flywheel.. what did you balance it with? They usually come neutral balanced and come with a weight you bolt on for externally balanced motors.. might want to check that.
EDIT: yea never mind.. you already got it..
Old Nov 20, 2004 | 07:55 PM
  #27
just to give a final update, the car is finally fixed. i ended up sending back the stock flywheel and the new spec flywheel back to spec. they matched the balance on the new flywheel to the old one. its finally good to go now!
Old Dec 22, 2004 | 12:53 PM
  #28
slp223's Avatar
how about a new update is everything still ok. I fried my second stage 3 and just ordered a stage 5 and reading things like this scares me.
Old Dec 22, 2004 | 04:23 PM
  #29
well i have only put about 100 miles on it. it winter here so i wont be driving it until spring now. i know that it is fine though.
Old Dec 22, 2004 | 04:45 PM
  #30
Mikey97Z's Avatar
I'm using a Stage 3 with stock flywheel for 2 yrs, 10k miles, almost daily driving, many track passes, ET Streets, and I still love this clutch! I would say the Stage 4 is the way to go!
