1996 transmission into a 1995 F Body
Old Apr 20, 2008 | 03:49 PM
BMX Dad's Avatar
I have a good auto trans out of a 1996 3.8L and plan to put it into a 1995 3.4L with a bad trans.
What do I need to do to make that swap work/
Thanks for your help/ advise.
Old Apr 20, 2008 | 06:15 PM
12SCNDZ's Avatar
'95 and '96 use different 3-2 downshift solenoids with different resistances. If you swap them, you'll throw a code, and cause the trans to go into "limp mode". I've seen people simply swap the solenoids, but the actual valve is different. I've seen this mismatch cause WOT 3-2 downshift issues.
Frank
CPT
Old Apr 20, 2008 | 08:20 PM
a4z28's Avatar
I think 94-95 trans can swap but to notice it should have pwm in the front pump frank can tell you for sure though.
Old Apr 20, 2008 | 09:42 PM
jay_lt4's Avatar
1994 f-body 4l60e are not pwm
Old Apr 21, 2008 | 05:27 PM
jpack24's Avatar
Correction, 94 and early 95 are non PWM.
Old Apr 22, 2008 | 06:09 AM
12SCNDZ's Avatar
I've never seen any 1995 4L60E that were non PWM.
Frank
CPT
Old May 2, 2008 | 05:01 PM
jpack24's Avatar
I have one in my car. (car is 94 with a 95 trans in it) It is rebuilt by a Proformance, but never converted the pump. I also have a friend that has the orig in his 95 which was early production run and it is non PWM.
calaban
May 18, 2020 06:43 PM
CARiD
Feb 9, 2015 09:35 AM
Jan 5, 2015 07:14 PM
joe777107
Dec 1, 2014 09:32 AM
siguy
Nov 27, 2014 10:07 AM
