1995 z28 motor swap
Old 03-29-2013, 11:18 AM
kcmolinski's Avatar
1995 z28 motor swap
Hey guys I have a 1995 Camaro Z28 automatic, blown motor, have another motor out of a standard car 1995 as well, will this work without issues being swapped from a two different transmissions??
kcmolinski is offline
Old 03-29-2013, 11:23 AM
Chet1185's Avatar
Pretty sure the engines are the same. I'd say only difference would be wire harness but your swapping engines so no big deal.
i'm sure an expert will assist you soon....lol
Posted from Camaroz28.com App for Android
Chet1185 is offline
Old 03-29-2013, 08:42 PM
Re: 1995 z28 motor swap
If the engine is out of another Z, it is identical. You will obviously use the harness that goes with your current automatic. The manual trans engine will likely have a pilot bearing in the end of the crank that you will need to remove.
shoebox is offline
Garcia5
07-07-2022 06:51 PM
calaban
05-18-2020 06:43 PM
10-31-2016 11:09 AM
01-05-2015 07:14 PM
pete53
12-09-2014 07:31 AM
Quick Reply: 1995 z28 motor swap
