1995 z28 motor swap
1995 z28 motor swap
Hey guys I have a 1995 Camaro Z28 automatic, blown motor, have another motor out of a standard car 1995 as well, will this work without issues being swapped from a two different transmissions??
Pretty sure the engines are the same. I'd say only difference would be wire harness but your swapping engines so no big deal.
i'm sure an expert will assist you soon....lol
Posted from Camaroz28.com App for Android
Re: 1995 z28 motor swap
If the engine is out of another Z, it is identical. You will obviously use the harness that goes with your current automatic. The manual trans engine will likely have a pilot bearing in the end of the crank that you will need to remove.
Garcia5
Jul 7, 2022 06:51 PM
Jan 5, 2015 07:14 PM
