12-Bolt question
Old Apr 18, 2004 | 10:38 PM
WhtLT1's Avatar
12-Bolt question
Ok so here's my question, if I get a 12-bolt out of an ls1 car can I just bolt it into my lt1 car? Is it the same dementions? Anything else I should look for?
Old Apr 18, 2004 | 11:26 PM
fstenuf's Avatar
might get more results if you put this thread in the drivetrain section
Old Apr 18, 2004 | 11:27 PM
97 RedSS's Avatar
I believe the back braking plates are pointed towards the rear of the car on the LT1 and its the opposite on a LS1..Besides that I think they are the same..
Cody
Old Apr 19, 2004 | 06:49 AM
WhtLT1's Avatar
Cody
So basically it would work as long as I got new backing plates then right?
Old Apr 19, 2004 | 11:39 AM
HBHRacing's Avatar
as far as a moser 12 bolt goes.. the LT1 uses a 1/8 inch shim that is pressed onto the axle and the LS1 doesn't
Old May 4, 2004 | 09:03 AM
DCam's Avatar
i put an Ls1 rear-end in the back of my 95 Z28 and you need to get the Ls1 brakes because the emergency is like a drum brake on the inside of the rotor. You would need Ls1 rotors, emerg brake cables, calipers, emerg. brake cables because they also use different brackets for the emerg brake. But it really isn't that bad if you find an Ls1 rear-end at the right price and i like the emerg brake setup better anyway.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
canbaufo
Parts Wanted
Feb 21, 2015 11:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
RichJ
Sep 14, 2002 09:37 AM
