12 bolt - pros/cons 3.73s or 3.42s
Subscribe
Apr 23, 2011 | 02:50 PM
Trying to decide what gears would be best for me.
On street tires, will 3.73s be much quicker (1/4 time) than 3.42 in a GM 12 bolt? I wont be running slicks and this car is used to blast around town and down the highway?
Im about to pull the trigger on a 12 bolt and was wanting some feedback from you 12 bolt owners...
Reply
Apr 23, 2011 | 03:53 PM
Re: 12 bolt - pros/cons 3.73s or 3.42s
Since you have the 383ci. and a 3,600rpm stall Vigilante, and you are running street tires, 3.42's might be to much gear here. If you were going to run 27.5" - 28" street Drag radials, then 3.73's might be a better way to go on the street.
Reply
Apr 23, 2011 | 07:28 PM
Is there a major diffrence in 3.42s/3.73s since its a 12 bolt instead of the OE 10 bolt? How much traction is added by a 12 bolt?
Reply
Apr 24, 2011 | 05:22 AM
A 12 bolt does not add traction. A 12 bolt will take more abuse before breaking than a 10 bolt.
"Is there a major diffrence in 3.42s/3.73s since its a 12 bolt instead of the OE 10 bolt?"
are you asking difference between 3.42 and 3.73 OR between 12 bolt and 10 bolt ?
Reply
Apr 24, 2011 | 11:03 AM
3.73 thru a 12 bolt with street tires
vs
3.42 thru a 12 bolt with street tires
I just wana make the BEST choice. The car will be used to blast around town and thats about it. Mayb a time of 2 down the strip.
Reply
Apr 24, 2011 | 06:20 PM
"blast around town" = 3.73s' in a 12 bolt
Reply
Subscribe
