10 Bolt Rear Removal
Old May 23, 2006 | 09:56 PM
CamaroGuy22's Avatar
What do I need to do to remove it?
Old May 23, 2006 | 10:00 PM
dsmawd350's Avatar
Re: 10 Bolt Rear Removal
take off the wheels, take the brake calipers/lines/ e-brake cable off, unbolt the driveshaft, torque arm, shocks, panhard rod, and lower control arms
Old May 23, 2006 | 10:10 PM
Alright. Thanks haha I figured there was nothing to it. Most of that stuff is already off just figued I would ask anyways.
Old May 24, 2006 | 11:54 AM
Z28_95RIDE's Avatar
All I did was pull the calipers, left everything attached and set them up on the axle.
I removed the rear cover, removed the pin that holds the axles apart. I pushed the axles in far enough to remove the C keeps inside the rear housing and then pulled the axles out about 8 inches. I then unbolted the bearing caps and lightly pried the diff forward. Be careful here because it can fall all the way to the floor/ground.
Old May 30, 2006 | 02:36 PM
Bawls's Avatar
It's simple, I had mine out and a new one back in in about 4 hours.
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
