10 bolt ?
10 bolt ?
so i'm thinking of having 4.10's installed with some of my tax return money. should i also replace the diff in the rear or does it even matter? and im also wondering if i should buy the spec stage 2 or 3 clutch? mods in are in sig...
What are your goals for the car? If you plan of hitting some high numbers and plan to attend the track regularly, I would forget about installing gears in a stock rearend and save up for something more durable. If not, then some fresh gears and a new posi in your existing 10-bolt would be alright.
4:10s are perfect for M6's. It is the most popular gear set on M6's on the board. If your posi works well then I wouldn't replace it. Get you a stud girdle for a little added insurance.
You dont have a lot of mods, so your 10 bolt should be ok as long as it is cared for. Then again enough good traction can brake it. There is no definative amount of abuse it can take, but if it is working for you, then stick with it till it brakes or is about to brake.
Forget the gears and start saving for a real rearend. The better the clutch, the more strain on the rear. Add some tires that can hook and the lifetime of that rear is greatly reduced. Or do you drive your car like grandma does?
His mods would put him around the 300rwhp range. He should be good on his 10 bolt for a while.
Victor Lamb
Aug 26, 2017 02:52 PM
carguyshu
Jan 22, 2017 11:19 AM
