02 S-series Rear-End into 96 Z28 M6??
I've got a posi rear out of a 2002 S-10 Blazer Xtreme that I have in the garage from a previous project. It's a fully intact axle assembly complete with disc-brakes. I have Richmond 4.10s installed in the rear-end. Is it possible, and if so, what is involved, to use this rear-end in my 96 z-28 M6. I only ask because I'm thinking they're the same size and I wouldn't mind getting away from the 3.23s that are in the camaro. I assume it would only be possible to swap the rear-end assembly, not the full axle, and i'm fine with that.
Thanks for your help.
As info, car is bone stock, 100K miles.
Re: 02 S-series Rear-End into 96 Z28 M6??
your terminology
fully intact axle assembly/full axle=rear end
rear-end assembly=carrier/posi
the Z has/uses 28 spline axles,the S10 uses ? spline axles but probably 28 spline. If it has 28 spline,the carrier/posi with ring gear and pinion gear from S10 is usable/swapable into Z rearend. Both would have to be completely dis-assembled and setup would be very involved. pinion depth,pinion preload,lash,carrier bearings preload.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 11, 2015 06:10 PM
Jan 5, 2015 07:14 PM
