**** pilot bearing
Old Sep 26, 2005 | 09:31 PM
  #16
viper03af's Avatar
Re: **** pilot bearing
Originally Posted by Demus
Well I tried everything. Even a blade for cutting steel in the jig saw was not making it very far. I did however find a wonderfully elegant solution.
Took 5 minutes. Anyway, the new one is in, and the clutch is installed.
exacly what i did with my V6 took 5 seconds and got the new one in it
Old Sep 27, 2005 | 06:12 AM
  #17
autoxr's Avatar
I did the packed grease trick when I did mine. A 10mm 1/4" drive socket w/3" extension worked perfect. A little messy, but it worked. Took about 15min total. And my engine was still in the car.
Old Apr 18, 2006 | 04:04 PM
  #18
SiCk PuPpY's Avatar
Re: fing pilot bearing
Originally Posted by 1racerdude
Get a tap the right size I believe a 5/8" standard will fit. If it don't drill it the right size. Run it in until it bottoms on the crank and keep turning. It will jack it out.
I just did this and it worked like a charm!
Ericksd
Jan 20, 2016 06:07 PM
Bxlt1
Sep 29, 2015 03:18 PM
Bxlt1
Sep 17, 2015 08:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
