will XP's fit an Fbody? and other rim questions
Old Dec 11, 2004 | 10:04 PM
IrocSS85's Avatar
do they make XP wheels that fit out fbodys? what backspacing do you need on a 15x8 rim? the 15x10s are 7.5" backspacing right? this would be for an LS1 car also, what spacer will the fronts require? and what studs to use to replace the stock ones with for the above rims? will be buying some for my dads 02 TA after the holidays before spring time. and do you clearance the rear calipers the same on the LS1 cars as the LT1 cars? Ive heard you gotta remove more material. but from the same spot only?
thanks
chris
Old Dec 16, 2004 | 11:14 PM
FASTFATBOY's Avatar
Re: will XP's fit an Fbody? and other rim questions
I have a set of Weld Draglite XP's...15x10 with 6.5 bs and 15x4 frontrunner, yes they fit the car very well(my 94 anyway) No grinding on calipers needed. Mine are for sale with lug nuts for $700, in very good shape. The frontrunners are pretty rare, not many sets were made.
Speedadikk@Comcast.net
David
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
Kato
Jan 26, 2015 09:21 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
