will brakes clear a 15 inch rim?
Old Dec 17, 2007 | 02:45 PM
rLyTa1n's Avatar
Will the stock brakes on my car clear a 15 inch drag wheel, something like a 15x10? Or will I need to take them off and all that crap, I don't really wanna have to do that, so if they don't clear then I wont even bother taking the brakes off. Just wondering, thanks in advance for your input!
Old Dec 17, 2007 | 02:46 PM
JakeRobb's Avatar
Super Moderator
From what I've heard, you'll need to grind on the calipers a little.
Old Dec 17, 2007 | 02:57 PM
rLyTa1n's Avatar
Hmm...not too bad. I'll wait for some more replies or look around the internet alittle more before I buy some rims, thanks for the timely reply.
Old Dec 17, 2007 | 04:02 PM
Shon Herron's Avatar
To clear stock brakes with no grinding your options are Bogarts. We can set you up with a set that will clear stock brakes.
If you are looking at the Weld ProStars or Draglites then you will have to grind the poop out of the rear calipers (ie remove the cooling fins) and then either grind the front calipers or run a 5/16" spacer on the front and run longer wheel studs.
You can run a 5/16" spacer on the rear but do not recommend this for drag racing b/c even with longer/upgraded studs the chances of breaking them are greater and that is not fun and could be harmful to yourself or others.
Old Dec 17, 2007 | 04:11 PM
3DFORMULA's Avatar
I borrowed a set of 15" centerlines(slicks and skinnies) and just throwed them on. I did not have to do nothing. He did tell me that his LS1 car brakes had to be ground on. There is a difference in the brakes I guess on the '98 and up. With your '96, you will probably be alright.
Old Dec 17, 2007 | 04:34 PM
The requirements for fitting 15" Weld Pro-Star or Draglite wheels are covered in the FAQ stickied at the top of the Wheels and Tires forum topic page.
https://www.camaroz28.com/forums/sho...d.php?t=312442
Old Dec 17, 2007 | 07:11 PM
rLyTa1n's Avatar
Thanks for that page, I have no idea why I didn't check there before, big duh on my part, thanks though, thats all the info (plus more!) that i'll need, thanks!
Old Dec 17, 2007 | 08:08 PM
LOL@myself, I dont know why I forget about the Centerline wheels, that is what I am running, I have had a set of warriors and telstars now.
both fit right up with no issues.
DUH, on my part...
dluna333
15
Mar 13, 2015 12:30 PM
siguy
Nov 27, 2014 10:07 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
