Why won't it 60ft.??
Ok, so i took it to the track friday night, got a new best 13.55 @ 101.95 on a 2.0018 60ft., i tried different techniques but still nothing, i was told 1.8s no problem with my set-up, my best was a 1.99 but it turned into a bad run, whats happening is it is just laying over (bogging), unless i leave at a lower RPM & not dump the clutch & hammer it, i tried it at 5000 & dumped the clutch & got a slower 60ft., so i left at 4000 & didn't dump the clutch & it netted a better 60ft., The car is dead hooking every time so thats not the problem, i just don't think I'll ever see better then 1.9s out of it, it just doesn't recover (engine) fast enough once it hooks & boggs, could it be the DA/tune, it was in the 2500ft. range.
97 Z28 M6, Bolt-ons, CAI, PS LTs, Mag. cat-back, Hypertech, NGKs, 10mm wires, B&M shifter, Moser 9", 4.11s & spooled, custom d-shaft, LCA relaction brackets, BMR t-arm, 26" Hoosier DRs.
I think our peak torque is at 4000ish rpm, so I'm gonna start leaving at that rpm and very slowly letting out the clutch.
I am having the EXACT same problem. I made 10 runs with a 5krpm clutch drop and I'd bog down to 2200rpm every time. Even when I tried to feather the clutch it would still hook and bog.
The only way this cars going to 60ft. is a steeper gear, but that'll kill off the 1/4 times, i'm trapping at 52-5300 now, thats just about right with the stock cam.
The suspention is basically stock other then the LCA relacation brackets (bars are in the middle hole), tubular LCAs & Panhard bar, it seems to leave good, but its bogging the engine down enough to were it doesn't start really pulling untill the 60ft. is over, i am though at a Alt. of 1500ft. & DA was in the 2500ft. range, i'm sure that wasn't helping.
Stock shocks?. Your DA is good. We run alot in the 3000 DA.And pray for the 2500 DA. If you got the front sway bar still lose it. If on stock shocks get a good drag shock on all 4 corners if your a drag car only. Just my 2 cents
I used to pull 2.3 60' times in my old manual tranny 99 camaro. I put $1500 worth of suspension on it, to include QA1 shocks, all UMI hard parts, etc... After that, the car would constistently pull........................2.3 60's
I was at the track on friday, and I pulled a 1.85 60' on a mostly stock car, with street tires. I couldn't figure out how I did it. I just know that I did, and that the car is capable of it.
. This leaving @ 5-6000 & dumping the clutch ain't working at my HP level.
I think i need to stay in the power range of the engine when i leave, so i'm believing now i need to get a small spin (like 1 revalution) off the line so it doesn't bogg down near as much, but then hooks after then engine has a fighting chance & the car is in motion, if i add another 100 rwhp, there is no doubt it'll 60ft. much better leaving hard or put a BB in it lol, that'll give me some torque
When we were doing the LT1 stuff, and had 4.10s, we had to dump it at 6k for it to take off, due to the weight (this was before huge weight reduction started) and even after we left at 6k with 4.33s but what really suprises people is that the car would run the 60' and 330' better if it spun some off the line, not alot but some, so as some have mentioned, air the tires up some.
Key is to have the most amount of air in the tire for it to hook the way you want it to, more air is less rolling resistance down track as well....
here is an example of some spinnage but a 1.5x 60'
http://www.youtube.com/watch?v=KmJLAhNy-4U
Something has to spin, it is easier if the tires spin, since we do not have much control over the LT1 style clutch set ups. We ran a stock replacement clutch (most of the runs) or a Spec Stage 2 (on 11.80 pass) for a Mustang, ie smaller diameter than stock LT1 by half inch i believe it was....
Shon, thats a nice video, thats exactly how i should be leaving & those tires spin more then 1 revalution too, but just enough to "sling shot" the car forward.
Thats hooking
