who has the best 60' on the stock convertor?
Old Oct 8, 2003 | 08:57 PM
JoshGuitar's Avatar
I got a set of ET Streets a couple months ago, and haven't seen much improvement in my 60' times. I got one 1.995 60' my last time out...my best 60' on street tires was a 2.0x, and I got consistent 2.0's on street tires. I'm actually less consistent with the ET streets, I guess I need to practice more . I'm talkin everywhere from that one 1.995 to some 2.1's and I think even a 2.2 or two .
I know a high stall convertor would most likely drop those down to consistent 1.7's or 1.8's, but I'm eventually converting to a M6 and don't want to put any more money into my automatic tranny. Is anyone out there getting consistent sub-2.0 60' times with a stock convertor? (preferably with a similar power level to me). If so, how ya doin it?
Old Oct 9, 2003 | 11:17 AM
ltlhomer's Avatar
Where's Joe (ramair95ta)? He has cut a 1.78 or so on completely stock motor w/ stock converter. No boost and no juice. I'm sure he'll jump in here.
Old Oct 9, 2003 | 11:46 AM
Javier97Z28's Avatar
Moderator
Man I've seen that and I still have no idea how that's possible.. but oh well :P
Best I ever cut on stock converter was a 1.9 on Nitto's.. ET Streets on a stock converter car is probably bogging.
Old Oct 9, 2003 | 05:34 PM
Mike Comp T/A #57's Avatar
I average 1.67 with 17" drag radials using a stock converter and stock 3.23 gears.
Old Oct 10, 2003 | 07:34 AM
JoshGuitar's Avatar
What kinda 60' times were you getting when you were in the mid 13 second range? A good bit of your faster 60' is obviously because you're making alot more power...just curious what that translates to at my power level
Old Oct 10, 2003 | 09:36 AM
Coolformula's Avatar
I went to the track with BGF dr and I was getting under 2.0 a lot, I screwd some and got 2+ oh well.
I was getting 1.99 but good, I got one 1.95 and 1.97 I thoguht that was pretty good,
Old Oct 10, 2003 | 09:52 AM
CanIroc's Avatar
I;m running et streets now as well. I pull consistent 1.95-2.05 60 ft's. I think that's as good as its going to get with the stock stall in there.
Thinking about getting a slightly higher stall this winter.
Bob
Old Oct 11, 2003 | 04:25 PM
taner's Avatar
From: Windsor, Canada: Home of the FASTEST LT1 & LS1 6 spds :)
1.81 60' on stock stall, on nittos with 3.73 gear. cold air and catback. 13.49@101.2....... in the wifes Z
Old Oct 11, 2003 | 09:31 PM
91RSLT1's Avatar
1.86 with goodyear eagle f1 steel, 245/50/16, lowering springs, and mods in sig.. It was only once but oh well.
Old Oct 12, 2003 | 01:46 AM
steve40's Avatar
1.86 today on 26" et streets
1.88 on bfg drag radials
3.73's, as&m headers, corsa catback, relocation brackets
Old Oct 12, 2003 | 05:37 AM
CanIroc's Avatar
steve, what kind of rpm are you coming out at?
Bob
Old Oct 12, 2003 | 10:09 AM
steve40's Avatar
around 1000 rpm or flashing the converter where all pretty close
1.88 flashing
1.86 at 1000
Old Oct 12, 2003 | 11:47 AM
bad93z's Avatar
the best 60' I've cut was a 2.05 on Kelly Charger tires(they suck), lakewood lower control arms, and !front swaybar.
Hopefully I'll pull a 1.9X or better after the eibach drag springs
Old Oct 12, 2003 | 12:11 PM
OneFlyn95z28's Avatar
Kurtis Tamez cut a 1.55 on his. stock motor and trans.
Old Oct 12, 2003 | 08:31 PM
89'Formula's Avatar
Bob
The higher stall might help a lot but I think you could get lower than that on et streets. i pulled 1.88ish with a bone stock 89 305 TPI w/ 2.73 gears. Try a little higher tire pressure.
