Where to set tire and airbag pressure?
Old Sep 11, 2002 | 09:58 PM
RichJ's Avatar
Post Where to set tire and airbag pressure?
I'm going to be running 26x11.5x16" ET Streets on stock 16x8s on Friday for the first time and was wondering about where I should be on tire pressure and also about how much pressure to put in my passenger side airbag.
Car has 1LE springs and Bilstein HD shocks if that matters.
Also, I've got a steel Street Twin, 12-bolt rear and around 360 rwhp NA with heads/cam.
Thanks for any help,
Rich
Old Sep 12, 2002 | 07:10 AM
TedH's Avatar
Post
I run 15.5 pounds in mine, bit I have tubes and 10" rims...
Make sure you mark the tires on the rims so you can see if they turn on you. Mine turned back when I only dyno'd 320hp, so keep an eye on it.
I think this will be a trial and error process. I run about 18 pounds in my airbag. Depends on the weight transfer... I have drag springs and shocks, no sway bar, and a 6 point welded bar. I would probably start around 14 and go from there if I were you.
'94 Black Z28, 383, 700R4
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
http://www.downtime.cz28.com.index.html
Old Sep 14, 2002 | 07:19 AM
RichJ's Avatar
Post
I posted elsewhere about my best run with the new tires, but the pressures that worked best were 15 in the tires and 15 in the bag. Also, think my guage may read a little high, so that may be more like 14.
Thanks for your advice. It helped me get that elusive 1.6x short time.
Rich
Old Sep 14, 2002 | 09:37 AM
TedH's Avatar
Post
Thanks for the "Thank you" Congrats on the performance.
1/8 ET: 7.48
1/4 ET: 11.86
1/4 MPH: 112
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Ken Cemo
Feb 13, 2015 08:37 AM
Ken Cemo
Jan 27, 2015 08:45 AM
hotrodyou1
Dec 20, 2014 10:05 PM
