What's your trap RPM ?
Old Jul 18, 2009 | 06:50 AM
  #16
kazman's Avatar
Here is my $.02. What RPM are you currently crossing the finish line? I would say you are looking to cross at 6000 rmp. Bolt-ons will change the results (gears, tire diameter, converter, headers, shift points, etc).
In my 95 Formula convert, stock, auto, 2.73 gears, 26" diameter drag radials. I bumped the 1-2 shift point up to 50mph and moved the rev limiter to 6200rmp. I was able to cross the finish line in 2nd gear at 6000rpm. I was able to duplicate this in a 95 Formula hardtop.
I have another formula , 383lt1, turbo 400 auto, 27" diameter tires. I have changed gears and tires to get the finish line rpm desired. Nothing like spending $$$ to have gears installed only to have the work redone the following week. I made the mistake of changing gears and tire diameter at the same time. Duah, make only 1 change at a time.
1" change of tire diameter = one jump in gear ratios
26" diameter tires and 3.73 gears = 27" diameter tires and 4.11 gears
I would do the boltons first then see where you at rmp wise. Then make addjustments via tire diameter and gears.
Old Jul 18, 2009 | 10:47 AM
  #17
Bayer-Z28's Avatar
My first (ever) three passes last night: The shift light came on in third right before the trap. I had enough tach left to roll thru. Stock gearing, obviously. So about 6500rpm.
Old Jul 19, 2009 | 01:51 AM
  #18
deerslayinrenek's Avatar
I tried that once, the car nosed over when it hit the rev limiter about 30ft before the finish line
Old Jul 19, 2009 | 09:54 AM
  #19
Bob Cosby's Avatar
Get it to hit the rev limiter around 100 ft out and you'll be damn near perfect!
Old Jul 19, 2009 | 10:42 AM
  #20
JakeRobb's Avatar
Super Moderator
Mine hits the limiter about 300 feet out in 3rd gear (M6). So, I pull 4th gear and add about 6mph to my trap speed instead. It's worth a few tenths on my ET.
My goal is to put in a set of 3.73 gears and then add enough power to max out 4th (~125mph).
Old Jul 19, 2009 | 11:19 AM
  #21
Bayer-Z28's Avatar
^ What would 4.11's trap? I really want gears.. been wanting a set of 3.90's.. Good median between 4.11's and 3.73's...
Old Jul 19, 2009 | 11:45 AM
  #22
Bob Cosby's Avatar
You want to be on the limiter in 4th gear with an M6, 3rd gear with an A3/A4. I would absolutely pull 4th gear at the 1000 ft mark if I were at my shift point. However, that simply means that you are grossly under-geared for the 1/4 mile.
Old Jul 19, 2009 | 09:10 PM
  #23
JakeRobb's Avatar
Super Moderator
Assuming a 6500rpm rev limiter, 1.00:1 trans ratio, 275/40R17 tires, and everything working right (no traction issues and plenty of clutch grip), your maximums are:
3.23 - 153 mph
3.42 - 145 mph
3.73 - 133 mph
3.90 - 127 mph
4.10 - 121 mph
4.30 - 115 mph
4.56 - 108 mph
Yeah, that's because it's (mostly) stock. I'm just working with what I have until I can afford to do something about it.
Old Jul 20, 2009 | 01:13 AM
  #24
HRE's Avatar
HRE
Would the six speed guys get your own thread please. I started this asking about mod stock engs with AUTOMATICS !
Old Jul 20, 2009 | 01:42 PM
  #25
Z-RATED94's Avatar
Re-read post #15.
Old Aug 4, 2009 | 05:30 PM
  #26
The Engineer's Avatar
I believe Warren Johnson once said, "red-line + 5% at the stripe!" Therefore, you should work backwards from that goal (trap RPM), selecting your gears and slick height that will place you there (your red-line + 5%).
With my LTX Camaro I’m turning 7K+ at the stripe with 127 MPH.
WD
Old Aug 5, 2009 | 12:00 PM
  #27
5SPDCHK's Avatar
4.86 gears with a TH400 trans and 32" tall tires. I shift at 6500 rpms but I go through the traps just below 7300 rpms.
Old Aug 5, 2009 | 02:41 PM
  #28
Your car is an example of the Warren Johnson trap RPM theory. But with a few extra trap RPM beyond +5%. Specifically, you're at +11%
WD
Old Aug 5, 2009 | 03:13 PM
  #29
kazman's Avatar
WD
Tricky bracket racers there. Her crew chief may have instructed her to short shift in order to slow the ET down a bit. Gives a high MPH to ET ratio for a top end advantage.
Old Aug 6, 2009 | 11:40 AM
  #30
5SPDCHK's Avatar
WD
I never really understood the whole +X% thing until I started driving my own car. I used to sit in the stands up at the top end and wonder why the shift light was on in most cars while going through the traps. The first time I ran my car I thought I broke something because my shift light was on and I had no more gears left... DUH!!!
