Whats everyone's race weight?
Old Jan 12, 2007 | 11:07 AM
  #16
Jlo's Avatar
Jlo
Any of you all running tubular K members??
Old Jan 12, 2007 | 01:52 PM
  #17
JakeRobb's Avatar
Super Moderator
Not yet.
I want it more for weight distribution than overall weight. The front of the car outweighs the back by about 500 pounds, so anything I can remove from the front is a good thing!
Then again, I autocross, unlike most of the guys here.
Old Jan 12, 2007 | 04:33 PM
  #18
Ray@NitroDaves's Avatar
#3350 in the 94
Old Jan 12, 2007 | 05:06 PM
  #19
Jlo's Avatar
Jlo
Originally Posted by Ray@NitroDaves
#3350 in the 94
How did you get it to 3550? I'm planing on losing car weight do you have a k member?? please give details.
Old Jan 12, 2007 | 06:05 PM
  #20
AL SS590 M6's Avatar
Moderator
yep, that's part of how my weight is low with the HD suspension a rollbar and subframes.
Old Jan 12, 2007 | 07:48 PM
  #21
Duke's Avatar
I got my daily driver Cobalt down to 2444 lbs after taking the passenger seat out, the rear seats, the spare tire and jack, and swapped the wet cell battery for a dry cell Dynabatt. I know, not a race car, but I managed a 15.4 (base model, not a SS!).
Not sure how heavy my camaro is. I took alot of weight out of it but then again I added in subframe connectors, a heavy BMR torque arm, a 10 point roll cage, and went from a stock 10 bolt to a heavy 9". We'll see I guess.
Old Jan 12, 2007 | 08:51 PM
  #22
ws6transam's Avatar
Let's see, this fall I went to the fourth round of eliminations in my Warner Brothers edition Chevy Venture Minivan. After removing the seats, floormats, but not the spare tire, the race weight was 3,998 pounds.
The '84 Trans Am weighed in at 3460 pounds, with 1900 pounds on the front tires and 1560 pounds on the rear tires. Race weight was therefore 3460 pounds without driver. The car has a fuel injected V8, full interior, a T56 transmission, a 41 pound Spohn suspension & crossmember, T-tops, 65 pounds of S&W Chromoly six-point roll bar, Subframe connectors, full antiroll bars, and big, heavy 17 x 9.5 inch wheels on all four corners.
Old Jan 12, 2007 | 11:05 PM
  #23
I have removed the front and rear bumper supports, AC compressor, Condensor, all unused brackets, heat sheilds, radio, speakers, speaker wiring, light weight wheels/tires, windshield washer pump and resevoir, front and rear seat, light weight drive seats, power window motors.....etc
Still have stock K-member, A-Arms....
My car was 3680 w/T56, 10 bolt, and 4pt cage, no back seats.....
Old Jan 12, 2007 | 11:07 PM
  #24
here is a good read for all you guys that want to go on a diet.....
http://www.ls1tech.com/forums/showthread.php?t=17319
Old Jan 14, 2007 | 05:34 PM
  #25
Alphawolf47's Avatar
Best 1/8th was 9.45 with no mods. Race weight was 3400lbs + 160lb me so 3560. That was minus sub and amp and emergency fluids, spare tire still there. Ran a 9.50 with sub, amp, and spare fluids at 3530lbs + me. Hot sticky night, so times are a little off the norms.
This spring I will have times with a little diet taking place. I'll be going without seats or rear panels, subs or amp, spare will ride there but will wait in the pit area for me. Looking to come in around 3250 without me.
Old Jan 14, 2007 | 11:59 PM
  #26
CamaroRacing12's Avatar
every bit helps....when i go to the track next year im gonna do as much as i can...without ripping my car apart....im in the process of taking out the rear seats and belts.... it sux i just need to get some star wrench bits to use a rachet on the belts.....havent been able to get up to sears yet
Old Aug 21, 2007 | 10:57 PM
  #27
SILVERZZ28's Avatar
back to the thread.
mine with me and 3/4 tank 3938lbs
Old Aug 22, 2007 | 09:02 AM
  #28
am in the process of removing more weight...will update my race weight when completed
Old Aug 22, 2007 | 04:39 PM
  #29
AutoRoc's Avatar
3350 N/A
3420 with scuba tank, emergency front-mount gas tank, and supporting hardware.
Old Aug 22, 2007 | 11:04 PM
  #30
went to the track tonight... new personal bests et-13.65 and new mph- 102.8mph... raceweight was 3440lbs
