Whats everyone's race weight?
Old Jan 4, 2007 | 03:05 PM
CamaroRacing12's Avatar
i was just wondering what everyone's car weighed. if you could pplease supply year/make a4 or m6 that would be nice. and ur track times and mods so we can compare. that be cool.
tony
Old Jan 4, 2007 | 04:01 PM
LT1 POWR's Avatar
Info in sig.
Old Jan 4, 2007 | 05:21 PM
AL SS590 M6's Avatar
Moderator
Raceweight 3440. All safety equipment installed and all HD suspension.
Old Jan 4, 2007 | 05:56 PM
SABLT194's Avatar
Mine's 3665# and numbers are in the sig
Steve
Old Jan 4, 2007 | 08:34 PM
Stephen 87 IROC's Avatar
Last fall, it was just under 3100 pounds. Mine is a stripped down full race car.
Old Jan 5, 2007 | 01:13 PM
tx77015ls1's Avatar
car= 3410
Me= 220
Race weight= 3630
Old Jan 5, 2007 | 01:51 PM
cjmatt's Avatar
i wonder where all this weight is hiding?
Old Jan 5, 2007 | 03:51 PM
ABA383's Avatar
Last time I weighed it with me it was 3650, but I've lost a few and gained a few so it still should be around 3650..
--Alan
Old Jan 6, 2007 | 02:46 AM
OneFlyn95z28's Avatar
In the Sig
Old Jan 6, 2007 | 07:52 AM
The Engineer's Avatar
1997 Z28 = 3315
Me = 175
Race Weight = 3490
However, I'm adding a Wolfe chromoly 6-point roll-bar (60 lbs) and Moser 12-bolt (30 lbs), so my car weight will be increasing. I guess I'll need to cut-back on the beer and Bar-B-Que to make-up the difference!
WD
Old Jan 6, 2007 | 08:34 AM
JakeRobb's Avatar
Super Moderator
2002 Z28 M6
Mods: Lid w/ paper filter, Corsa catback
3546 lbs as weighed at Mid-Michigan Motorplex.
325hp/343tq at the wheels on a DynoJet
Best ET: 13.219 @ 107.55
Best MPH: 13.26 @ 108.80
I have yet to get a good launch out of the car -- my best 60' is a 2.1.
Old Jan 6, 2007 | 03:56 PM
Kevin97ss's Avatar
Info in sig. BTW I weighed 275 last time I weighed car at E-town.
Old Jan 11, 2007 | 01:40 PM
Bolt-on Bob's Avatar
Mine has to be 3320 for C/PS. Believe it or not, when I bought my '94 Formula it weighed 3360 bone stock. I'm 230 so I had to get rid of 270 lbs. Between lighter wheels/tires, AC/PS/EGR/AIR deletes, sway bar removals, lighter carpet, OEM exhaust removal, etc. I hope to be there pretty easily.
Old Jan 11, 2007 | 08:19 PM
Nice thing about Stock Eliminator is that although there's a minimum race weight, it doesn't specify where the weight has to be. You remove whatever you're allowed to remove then add weight back into the car where it will do the best to get back up to the minimum weight.
Since I just run brackets, I strip whatever I don't need out of the car.
Old Jan 11, 2007 | 11:04 PM
Steve69SS396's Avatar
Mine is 3,350 with stock sheet metal, full interior and A/C.
